I recently purchased a used power trim unit and some of the wire was exposed where it comes out of the motor (I have attached a pic), and I just taped around it and thought that would be it. However, after I installed the unit and bled the system to make sure there wasn't any air in it, it would work fine for a few minutes but have problems if it sat unused for a few minutes.
After sitting idle for a few minutes, when you hit the trim switch it moves really slow, doesn't sound like it is working correctly, and takes 5 sec or so to really kick in, but once it starts, it works great. So I started checking all the fittings trying to figure out what was wrong, to me it seemed like air was getting into the system somewhere. Then I noticed where the two wires were exposed and come out of the motor, there are small air/oil bubbles coming from that area.
With that in mind, is there a gasket that may need to be replaced or know wat the problem may be?
