Re: power trim problems
almost every trim motor regardless of 2w or 3w has a thermal breaker. it is a bimetal strip that bends open as it gets hot. on some motors it looks like a set of distributor points and on others it looks like a plastic block with wires. Trim system stopping dead and then running fine after brief wait is classic symptom of motor overheat. If it was a mercury, force, or volvo then I would go straight to motor and not suspect the wiring. But E/J has introduced all those extra connections plus a moisture collection device to hold them. That seems to be the number one cause of all things intermittent with OMC. So, if it was me, I would check the relay box first and the motor second. It's not likely to be a switch problem because of the way it cuts out and then comes back after short wait. With full bidirectional relay or solenoid wiring the switch doesn't carry enough amperes to act like that. If it was a short, then it would not have a consistent waiting period. However, the relay output does carry enough amperes to generate heat from bad connection. So it could possibly be a high current power or ground problem associated with the black box (input or output, could be either). If not the box, then almost sure to be a motor with a bad winding causing excessive current draw and tripping breaker.
