i have pulled apart my power trim pump. after i pulled out the bolts that hold it togather i found 4 balls and im not sure where 2 of them go. i was wondering if anyone had the diagram for the pump. im not sure what pump it is. I will try to describe the pump if that helps. it is a metal tank with 6 bolts holding the tank to the pump plate. There are 7 screws holding the two plate together for the pump. one of the balls are larger then the other 3 balls. It has 3 springs in it with one of the spring going to a small square block with two different size pins on each side. If anyone has the diagram that would help me out so much
