Power trim servo motor
owlcritic
Motors : Mariner 100 Off Shore - 1990 100HP 4cyl (serial no. 9586000 to 9629999)<br /><br />The servo gave up the ghost due to water damage and after providing the above engine data to the local supplier ( Power Boat World , Durban SA); I was supplied with an ARCO 6279 tilt & trim motor assy.<br />This however does not fit! The flange is too deep and angular - the old one had an angle of abour 20 degrees.<br /><br />What is the correct part for this unit and who would be the accredited agent in Durban or even Johannesburg?
parkert50
Re: Power trim servo motor
Do you have a single or three ram trim and tilt system?
owlcritic
The system is a THREE RAM - pardon my ignorance ,I did nor consider the tilt cylinder a ram...<br /><br />Now can someone help?
