power trim switch
tednugent
My johnson outboard trim switch will not work when in forward gear at all from the throttle handle but will work from the front control panel. I have a 81 ranger bass boat with a 85 hp jophnson outboard.I was hoping someone could get me started in the right direction to fixing this problem thanks.
rndn
Re: power trim switch
It may be as simple as the wire coming off the switch when the lever is moved forward or the wire chafing.
