wasn't sure where to post this...the site moderaters might want to move it to another catagory...I want to caution those who have power trim systems on these mercury motors....if you have a leaking Hydraulic Ram, and if that leaking ram sets below the water surface...it will either seep water into the ram in the down position, or it will suck water into the ram when you trim the engine up....if this water intrusion starts, it will dilute the oil in the reservoir, it can potentially over-fill the reservoir with more water than oil, so much to the point, that it can actually push water/oil mixture up into the motor assembly, ruining the motor...i specialize in rebuilding these systems and i see a lot of pumps in this condition...the field and frame assembly around the armature is full of a rusty goo substance, then when the unit sets for awhile, the armature gets locked-up to the field and frame and will not spin...i have taken pumps apart that looked like they were at the bottom of Lake Erie for years...im telling you, if your rams are leaking, you are taking a big risk in ruining your pump or rams....
