I have a 77 Johnson 140 that will trim up but not down. I had a problem with a bad o-ring on the manual release valve, so I replaced it and I recently drained the fluid and replaced it, and it will trim up beautifully but not down. The motor runs and it looks like it attempts to go down but can't. It should be full on fluid as I replaced it, and if you take the fill screw off when fully trimmed it leaks out. What else could it be?<br /><br />P.S: The battery is fully charged.
