power trim
dimitry
i've noticed that over short period of time (10 minutes) my 115HP Mercury motor little-by-little tends to move down when trimmed up. Is there a problem with the hydraulic system? How do I fix it?<br />thanks guys
JB
Re: power trim
Merc. Troubles topic.
dimitry
Re: power trim
Originally posted by dimitry:<br /> i've noticed that over short period of time (10 minutes) my 115HP Mercury motor little-by-little tends to move down when trimmed up. Is there a problem with the hydraulic system? How do I fix it?<br />thanks guys
Chris1956
Re: power trim
Dimitry, There are usually two causes for this. The most likely cause is a leaky piston seal in one of the trim cylinders. You may be able to get a rebuild kit to cure this, but it may require special tools to install the piston back into the cylinder, after you replace the seal. You will also need to isolate the problem to the correct cylinder (if you have two). The other cause is a defective control valve in the power trim pump. I do not know if this can be repaired, it may just need to be replaced.<br /><br />It would be helpful if you posted the year of your motor and described the trim/tilt system. It wll be easier to assist you.
timmathis
Re: power trim
I had A looe fitting and mine would go down .Be carefull and don't overtighten.
