Re: powerhead removal on mercury 4.5 HP outboard
I just had this problem before took of the nuts tryed to get it up no go I found that if you remove the studs put two nuts on the bottom lock them in them get the studs out I had a little corrosion around them stoping it from coming off it came straight off then .
