Powering a boat question
Lablitzwing
So this is kind of an engine question, kind of not.
I'm going to be coming into possession of a 1970's boat hull, it's a 1974 Starcraft Stinger hull, 19' long, dry weight ~1100lbs
It is rated for a 175hp motor, but I do not currently have access to one that large. Still saving and looking for a good deal on a decent sized motor (Thinking 100 - 135hp).
What I do have easy access to currently, don't laugh, is a 30hp Tohatsu 4 stroke. I know it would be slow as hell, but would there be any major issues if I were to drop this little engine on temporarily while I source a bigger, permanent engine.I know there is no chance in hell of planing the boat, but at least putting around for the time being it should work, not very big lakes so no really rough waters or excessive wind.
Thoughts from the experts?
roffey
Not an expert but my 2 cents worth is... I can't see any issues with it. If your looking to get out on the water and that's all you have, go for it. I can not foresee any problems. I think its a good idea. Float the boat and see what structural issues you have before to sink any serious money into it. You can wait for a smoking good deal on a suitable motor for it. :fish2:
crazy charlie
Put it on and put around.You should try to get your hands on the biggest prop that will fit so you can get some bite on the water to keep you moving along.If your 30hp has a speed prop on it you will troll only and wont be able to put it in reverse to stop boat on a dime.Charlie
Watermann
Is the motor a long shaft or short and is it a tiller model? If it's a short shaft with tiller that would be a problem on a long shaft transom boat with splashwell.
