powerpack
71whaler
I have a 1983 75HP Evinrude Model # E75TRLCTE. The #1 Cylinder is not firing. I checked the spark plug wire, good. Checked the ignition coil, good. My next step is to check the powerpack. I am following the OMC manual for the tests. My question is, if it is the powerpack does anyone know the powerpack part # of this model engine? I did a search here on the site and came up with an Evinrude/Johnson Power pack for around $80 and I want to make sure this is the correct one.
71whaler
Re: powerpack
OK, another question. If indeed the problem is the power pack, do I need to check the maximum spark advance after replacement and if so do I need a special tool to perform this? <br /><br />The manual says to connect the engine to a "proper test wheel" and to run it without the propeller or flushing adapter. During the test the motor needs to run at 5000 rpm in forward gear. <br /><br />Changing the power pack seems pretty straight forward, a couple of bolts and some wires, however I have never performed a maximum spark advance adjustment. Is this something the average Joe can do or do I need specialized tools and training?
ddbyrd3
Re: powerpack
Do a search on setting "WOT timing". Joe Reeves has an artical that walks the "average joe" thru this simple process, and gives additional ways of checking your WOT timing settings.<br /><br />Read a few of the post you will find in the search results and you will be able to do it very easliy..
wilde1j
Re: powerpack
If all you did was change the PP, you don't have to mess with the timing ... it didn't change at all.
MGuckin
Re: powerpack
Changing a power pack involves 3 connections + ground and 2 bolts. 30 second job. Try eBay for descent price for used as opposed to new. Even show up new occasionally.
