Powersift II Control Box
mjake
I have a Johnson 70hp model 70ESL74M. The control box (which is Powershift II) that runs this unit is messed up. I have taken it apart, cleaned it, put new grease and insure that the cables are loose. Put it back together, shifts find until I hook it up at the engine. I can shift it a couple of times and then it locks up. I can move it forword but not in reverse. It has me stymied. Now It will not go into the complete neutral position so I can start the engine. Any ideas out there.
MCM
Re: Powersift II Control Box
Hi M.jake,<br /><br />First thought that comes to mind is that something wasn't installed properly when you reassembled the box.<br /><br />Look there first.<br /><br />Good Luck,<br />Mike ;)
mjake
My thoughts also. I have spent the last two days taking it apart and back together. I would disconnect from the motor and it will work but when I reconnect will not shift from neutral position. Been in ishopmarine.com looking at their diagram and can't find anything that I left out.
MCM
M.Jake<br /><br />Make sure that the trunion is properly inserted in the slot to the front of the box & the trunion cap is in place, otherwise your control cable will float freely inside the box.<br /><br />Only thing that I can think of at the moment.<br /><br />Mike
jim_in_day
it sounds like the screw that locks the cable to the trunion is loose, without the resistance from the motor it would appear to work just my 2 cents
