Hi All,
I seem to be having a problem with F/N/R on my pre alpha 1977 MC-1 style drive - the one with the pre load pin.
I think the cables have stretched as when I try to go back to N from F, I have to go into R an inch or so to get it into N.
Sometimes it does not engage in reverse until the mercontrol lever is quite far back, once in reverse its ok.
The shift cables are on the transom assembly and not on the engine as i have seen.
Is there a way of finding out if it is stretched cables and if so a how to adjust ?
I have seen chrisa's you tube but am not sure if it applies to my drive or not ?
https://www.youtube.com/watch?v=-s_tgevX2aI
I have also found this -
http://www.boatfix.com/merc/bullet/89/89_04.PDF
But the bracket and location is different on mine....
Many thanks....multiple issues at present ...
