Hello,
I purchased a new impeller kit for my 1966 pre-alpha Mercruiser R Outdrive.
Anyone know where I can get a video or photographic guide on replacing the impeller..I am new to boating and have no idea where to start.
I will also take typed instructions as well...Is there two different areas in the outdrive that will need to be refilled with oil after this is complete? I see an oil fill screw at the top of the outdrive....once I take this screw out, will I fill it with oil from there? Will I need to put a new o-ring behind the screw? What type of oil do I use?
Also, where do I add trim fluid? Someone told me there is a reservoir in the engine compartment similar to a master cylinder reservoir in a car...but I cannot locate this.
Any help, videos, diagrams, links, photos, or instruction would be greatly appreciated.
