I think I have an MR140 Drive unit on my approx 1985 century.Serial # for transom drive unit is A382065<br />I think I have some U-Joint knock as there is a knocking sound when the trim is way up. I have to run with trim up to get out to deep water. How does one tell if the U-Joints are bad versus needing the C-Clips. The manual says If U-joint knocking is suspected, inspect for evidence of bearing caps hitting center socket. What is the evidence they are talking about? If they are very bad I will be able to tell. But how do I tell if marginal? Is any play allowed? Can I buy a permenently lubed U-joint replacement? I would rather buy a whole U-joint assembly rather than try and press bearings etc. If bad I will have to take off the top cover.Where does one get the socket to remove the 4 topcover screws, They kind of look like an inverted torx. I didn't see the tool listed in the 6A3R3 pdf of the merc manual.<br />Any help would be appreciated
