Pre-Alpha Question
sYnOnYx
Is the pre-alpha drive supposed to "Pee" as they say ?
You know a steady stream of water out of a hole on the side of the outdrive ? Or is water only supposed to come out of the exhaust in the propeller housing ?
Re: Pre-Alpha Question
Ayuh,... There are several drains that may, or may not be passin' water...
sYnOnYx
I'm just trying to determine if my impeller is working correctly. Just bought this boat and owner claims it was just replaced a month ago...
Ayuh,... If when ya start the motor, the muffs nearly quit bleedin' water, 'n water comes outa the prop, or the idle relief ports,...
It's Workin'...
