topdawg487
- Joined
- Jan 29, 2005
- 4
New at this. I have a 83 140 about to go to the shop for a rebuild i have 2 piston that sufferd what the machanic said was pre ignition. This will be the second time he replaces theese pistons. He assumed that a looose wire in the stator had caused the pre ignition.Well turns out he ws wrong read in the forums about timming. He told me he had set it 2 past??? when i got it on the water ran very slugish, when i went to take of the cover got electricuted pretty bad. so i was shock right through the cover. Went home notice spark jumping from plug wire to the head. Changed the plug wires still jumped i moved the wires away form the block as best i could didnt see the spark but could tell from sound of the motor it was sparkig someware. I would assume that the two cylinders are reciving tomuch power to jump through the insulation of the wire. But why? my ? is what are some genral causes of pre ignition? and does my problem ring a bell with anyone? thanks
