Pressure check used Fuel Tank?
DjPro
Can anyone add insight to how someone would inspect a used inboard gas tank before using it?<br />Pressure test? If so how and can an owner do it?<br /><br />I believe that the tank has been replaced from looking at the deck seam and mis-matched screws, but can't tell for sure.<br /><br />I just recently bought the boat and the fuel line was hooked up to a portable tank. No information is available from the previous owner.<br /><br />Any help would be appreciated.<br /><br />Boat info<br />1979 Boston Whaler Outrage w/ a 1987 150HP Johnson
Paul Moir
Re: Pressure check used Fuel Tank?
Not much of an answer, but up here the small boat construction regulations say a fuel tank must hold a pressure of 3PSI.<br /><br />There's a thread started by Kesh about testing a built-in tank. Here it is.
