pressure in lower unit (johnson 115 )
flatsman
This is a tech question -----if ya have pressure in the lower unit after the motor has been shut down for 16 hours , but when you loosen the plug water comes out, where is the leak? Is it the shifter shaft , the drive shaft or the prop shaft?<br />This is a 1996 115 hp ocean runner johnson. :rolleyes:
Dhadley
Re: pressure in lower unit (johnson 115 )
Yes. Or it could be an O ring or fill/vent screw gasket/O ring.<br /><br />I bet a vacuume test is the best bet for pin pointing it.<br /><br />Good luck!
flatsman
Thank you sir, hoped to get several responses for this one.
clanton
Just like Dhadley said, you have to do vacuum test, should have 15 inches. The prop shaft, and drive shaft have double seals, one keeps oil in, the other keeps water out. You could have a gear case that holds pressure and still gets water inside.
clanton
Flatsman you live down town Hahira?
flatsman
no , I am closer to Cecil Ga. How about you ?
clanton
South West Florida now, but My dad was born in Adel and I visit as often as I can. I will be at Hahira sometime this summer for a reunion.
