Pressure relief valve
borntobag
Recently stripped the head of my evinrude 60 (1983) in an attempt to find out why my tell tail is dribbling despite a new pump and found the pressure relief valve that sits just abvoe the t-stat is missing.
What significance does this valve have?
Dhadley
Re: Pressure relief valve
Without the valve the motor may run too cold at idle. The obvious effect is that it may not idle as strong as it could. A lot depends on where you are (water temp). At planing speeds it's possible, although not likely, the block could not be filling up with water completely.
With todays fuel I'd put one in there if it were mine. If you do a lot of ideling the plugs may last longer. Make sure you have the correct Champion plug. When they took the valve out they could have changed plugs for a different heat range.
