Pressure tank
58rude
New here, so let me say hi to everyone and tell you what a great forum you have. I have a 1958 Sportwin 10 that a buddy of mine gave me. I fix all their outbords so he picked this one up for me at a estate sale. Anyway, it did not come with the pressure tank. I am just going to throw a fuel pump on it and call it good. I see where some guys put a plate on the tranfer port cover for the pulse. Why can't you just drill and tap the cover that is there and put a nipple in it for the hose. I was just planning on using the little Mikuni pump that has the in and out and pulse barbs. Mine does not have the flat cover the other guys are mounting their pumps too. Thanks in advance.
ezeke
Re: Pressure tank
The easiest conversion is to use the upper bypass cover that was used on the more recent 10HP motors, part # 0305751. Check with sea-way.com.
58rude
Re: Pressure tank
Just called Sea-Way. They do not have the cover. So there is no way just to drill and tap the existing cover?
samo_ott
Re: Pressure tank
As far as I know other folks have done that. Here is a pic that someone posted awhile back from an 18. I forget who.
jay_merrill
Re: Pressure tank
I've never done this to a 10hp model and don't remember the layout or the motor, but if it has a bypass cover, there is no reason to replace it with a plate. In fact, the bypass cover may have a curved surface inside, so I wouldn't want to replace it, if that is the case.
Take the cover off, so that no drill shavings end up inside of the motor. If there are mounting bosses for the stock pump, my choice would be to use them. Those bosses would be drilled part way through and tapped with the correct threads. The center hole would then be drilled all the way through. Replace the cover, using a new gasket. Mount the pump, hook the fuel lines up and that part of the work is done.
Don't forget, however, that you now have a nipple under the carb that has no line running from it to a three "prong" fuel connector. Left that way, you will end up fuel/air mixture spraying into the cowl on each "backstroke" of the pistons. To fix this, remove the nipple and replace it with a flathead or panhead screw of the correct size, thread count and reach. Notice the emphasis on reach. If you put a screw in that is too long, it will hit the leaf plates, so be careful of this issue. You may also need to put a crush washer under the head of the screw, in order to get a good seal.
If you simply prefer the Mikuni, you can certainly go that route. You would avoid having to drill/tap the mounting bosses, but would have to take other steps to mount the pump somewhere else. From that point, yes, you could just install a nipple in the center boss of the bypass cover.
1946Zephyr
Re: Pressure tank
I sold the parts to a fella who did the conversion. I have an early 60's 10hp and I sold the bypass cover to him. Someone else here on iBoats bought the fuel pump, but just about any fuel pump will work, just as long as it doesn't interfere with your clamshell shroud. Check these places out for a bypass cover.
sea-way.com
engine blade and prop.com
outboard-parts.com
laingsoutboards.com
tcoutboard.com
fairwindsmarina.com
salvagemarine.com
marinepartsoutlet.com
outboardexchange.com
Superior Marine (800-338-9281)
budgetboats.net
americanoutboard.com
piratemarinesalvage.com
trixieslanding.com
mmmarinesalvage.com
tcoutboards.com
58rude
Re: Pressure tank
Thank guys. Thats what I thought I could do. I am just going to tap the existing cover. I already pulled it once and took a peek at the pistons and rings.
