pressure tanks
Bruce N
Just got 2 Rude Fastwins 15hp and one pressure tank. Any hunts for pressure tank use and refurbishing?
Chinewalker
Re: pressure tanks
Hi Bruce,<br /> Those tanks are fairly easy and inexpensive to clean up and refurbish. Rebuild kits including new gaskets, o-rings and hose can be had at www.vintageoutboard.com. The most common place for leaks on those is right at the connector, so make sure you replace those o-rings. There are several posts here on iboats regarding replacement of them and how-to...<br /><br />- Scott
rwise
Re: pressure tanks
The only problem I have had with mine was the gasket in the cap!
