Pressure test block/HX Volvo Penta 5.7Gi
whitesharkseeker
So I need to pressure test my VP 5.7Gi block for leaks. Suspect a blown head gasket do to water in oil but engine runs fine. From last post, salt water pouring out (and I mean pouring!) of RW reservoir. Engine now overheats. Pulled HX to pressure test but not much on web hot to do procedure. Read about bike tire but how do I plug up other outlets/inlets? My main question is: I may have two problems, bad HX and blown head gasket. How to I do a block test with heat exchanger removed? Pic of engine below. Thank you for help. Eric Mailander
cptbill
Make sure to look at the exhaust manifolds and risers probable that's were the problem started as for pressure testing the block I haven't heard of doing it that way .
, the way I've always seen it done was to introduce air into the spark plug holes one at a time and see or here where the air come out
Get HX tested. If that passes, re-install, block off inlet hose and two hoses to exhaust and use a standard radiator pressure tester (about $20 on amazon)
whitesharkseeker
Thank you for the help. I ended up placing a cut bike tire tube over the fresh water side of the HX and blocked the overflow tubes. Then emerged the unit in a water-filled ice chest and air bubbles came out two of the raw water ports. So guess it failed the test. The HX is now obsolete and terribly expensive if I could even find one. May have to just re-power. Thank you again guys.
as I told you in your other thread. take your HX in to a radiator shop and have them test. they can also repair.
and yes, a proper HX is about $800 just for the cooler, a complete kit is about $1500
whitesharkseeker
Thank you. My HX is sealed and I think the leak is inaccessible. I did an online search for the same type of HX and it is now obsolete. Anyway, I appreciate your comments!
Eric
Bullcrap
Take it to a radiator shop. Quit arguing and just do it
The end caps get un-soldered, the tube sheets re-brazed. Then the end caps re-soldered
Its done all the time.
So quit arguing, look up you local heavy duty radiator shop and get it repaired.
You already wasted 3 weeks
whitesharkseeker
Thank you. I get advice from so many people, many telling me to just re-power at 4,000 hours. If the HX rebuild fails or a radiator shop can't salvage it, can I just convert back to raw water? Just a thought.
at 4000 hours your motor is most likely tired. HX's can always be repaired.
whitesharkseeker
Roger. Just know I do really appreciate your advice. Thank you once again, I'm learning a lot!
Best, Eric
