Re: Pressure test lower unit
Jon, You can pressure test a LU. Drain the lube, remove the LU, put a bicycle pump on the vent or drain screw (rig up some kind of adaptor) and pump it up to a few PSI. Spray some soapy water on the waterpump base, shift rod prop shaft, vent screw and if no luck, remove the impeller and spray some on the driveshaft.
