toolsinbox
- Joined
- Apr 22, 2009
- 187
I have read some great sugestions to pressure test the outdrive gear case and I have no problem understanding that in addition I have all the components to do it so that is underway, but how do I insure the water impeller housing and stuff wont leak into the gearcase?
I put mine together, The lower with the upper and it went together fine. The water tubes just slide together and I cant understand how they keep a seal. Especially under pressure. Does one of the tubes bottom out into a seal of some kind? I see a sleave type of seal for one of the tubes but that wont take much pressure to cause a leak.
I just want to make sure this outdrive is solid before I bolt it up. Any and all help is great
thanks
thanks
