bspeth
- Joined
- Aug 30, 2013
- 758
R/MR Alpha 1 ser 6683545.I sent it out to get the upper resealed because I had gear oil in my u joint bellows. The shop mated the upper and lower units improperly and never pressure tested again after reassembly. Today I noticed that they even used the wrong gear oil. 80w-140 is what the invoice said. So I want to drain it and refill with 90w.While it is empty I would like to check their work.Can I pressure test accurately with the drive on and with out turning the drive shaft and shifting shifting the drive? I can rotate the propshaft but the boat is all laid up and I don't want to get back in there if I do not need to.Is there any harm in running the 80w-140?Thanks
