Re: Pressurized Fuel Tank Conversion
Hi B&L,<br /> Not sure who told you pressure tanks are hard to find and expensive, but they're obviously not looking very hard. When I've needed one I've been able to find them for under $40.00. There are usually a half dozen or more on eBay for about the cost buying a new OMC fuel pump to do the conversion. Also, if you root around your local marinas you're likely to turn up a few. Place an ad in your local Pennypincher type paper and see what turns up. Place an ad on the AOMCI.org site, too. Rebuild kits for the tanks are available through several sources (off the AOMCI.org links page). <br /> If you do add a fuel pump, there is no "kit" per se, as that motor never came with a fuel pump in any of its incarnations. You'll have to modify one of the port covers to accept the pump, plug off the pressure nub on the intake manifold, etc. Personally, I'd find a pressure tank for it.<br /> Good luck!<br />- Scott
