Re: Prestolite troubleshooting.
Any luck with your problem?
I think I must have the same problem. On my '87 Force 85, one CD module output was bad, but since mine is a 3 cyl. I had an extra output, which I figured how to use (I had to swap stator outputs around). All cyls around 125psi, rebuilt the fuel pump and cleaned up the carbs, I get a spark on all cylinders but it just seems to miss. I checked all ignition parts for resistance and all seemed ok.
Lots of advice pointing to the stator, but I'd rather have some proof before I drop $150 for the stator, not to mention the socket and puller I'll have to buy. I get a spike on the VOM when I turn the flywheel by hand, so I have trouble believing its that.
