Prestone Flush
scatgo
Any one ever flush there out borde in a barrel filled with something like prestone flush. Watched some you tube videos and it looks like the stuff like saltaway is useless.
dingbat
What are you trying to do?
Salt-away is a flush/ preventative. Used it for years to rinse down tackle at the end of the year for storage. It will no restore damage done by saltwater.
The primary cleaner in Prestone flush is Trisodium Citrate which is used to clean carbonate scale.
I've used a mixture of White vinegar and baking soda to remove salt build up for years. Works like a charm. Sometimes too well if you let it sit too long.
scatgo
Old engine. It can use a flush. And hope to prevent the overheating problems i had before.
dingbat
It really depends on what compounds are causing the blockage. Guessing a combination of salt, calcium carbonate and aluminum oxide.
Something like this would do the trick.
The secret is to monitor the ph of the solution. The solution neutralizes itself as it dissolves the compounds. The solution may need to be replaced a number of times before the job is done
slimdaddy45
Try some CLR i FLUSHED MY TRUCK CAUSE MY HEATER WASNT WORKING VERY GOOD AFTER THE FLUSH i HAD GOOD HOT HEAT OUT OF IT SO IT WORKED FOR THAT
