Prime oil pump new engine
henry1357
Hi everyone
What is the best way to prime oil pump/engine on new vortex v6 4.3 mercruiser engine...
Thanks in advance
Henry
henry1357
Re: Prime oil pump new engine
Thanks for link
Is there any way to do it without oil priming tool, I'm in spain and finding specialist tools is a nightmare
Kind regards
Henry
Levinz11
Maybe cut the end off of an old distributor and attach it to a drill? I'm sure Mr. Google has more ideas. Good luck!
Don S
Find and old Chevy distributor (V8 or V6) doesn't matter year or anything else. Then remove the gear, cap and rotor and hook your drill to the upper shaft. May take some grinding to fit your drill. Make sure all the grindings are washed off before use.
FreeBeeTony
Is the distributor installed?
If yes, I would ground the coil lead going to the dist cap, remove the plugs and turn it over with the starter.
henry1357
Thanks everyone
No chance of finding an old distributor
Turning over while coil grounded seems the easiest way but is there a chance of damage as the engine I assume will be completely dry
Kind regards
Henry
Don S
Make sure you take the spark plugs out.
Sure there is a chance of damage. That is why they recommend you use the priming tool.
henry1357
Ok thanks for all the info
Will try and find a tool or distributor
Wish me luck
Thanks again
FreeBeeTony
How much damage could there be?
There's no load and it's not firing........
NHGuy
You prime it to fill all the bearings, sliding surfaces and the filter. Prime it. It matters.
Don S
I have no idea Tony, he asked if there was a chance, and I said there was. I have no clue who rebuilt it, if assembly lube was used or just oil, or how long it's been setting. The bearings could be dry as a bone and no oil in the passages or filter. What do you think would happen if it was dry and he cranks it over 10 or 20 revolutions before the oil pressure builds up?
sschefer
The oil pump shaft has a slot in it. Find a flat blade screw driver that's long enough to extend up far enough so that when it's engaged in the slot, there is enough sticking out of the hole when the handle is removed to chuck into a 1/2" drill motor. Use a fairly heavy screwdriver with a 3/8 or 1/2" wide blade to avoid breaking the screw driver.
For you naysayer's I've been doing it this way for years. I don't think I know of anyone that builds motors that has the special tool.
Just in case though, (trying to cover all the bases here) -- The oil pump shaft is hardened and won't break and I've never broken a screwdriver but if you did you would retrieve it with a flexible magnet pretty easily. You do it the same way you retrieve a distributer shaft pin or broken distributor/cam gear.
Don S
You have to have the distributor housing in there to connect the oil passages. using just a screwdriver in a drill will only oil some of the main and rod bearing. Nothing for the cam and lifters.
Ayuh,.... I do it that way too, Tony,...
So far, the motors I haven't assembled myself, were assembled with Lube, as mine were...
No problems, so far... I even got a converted Delco hangin' on the garage wall,....:rolleyes:
