hey guys thanks for your thoughts and suggestions, will let you know the results, just been too hot to take the boat out<br /><br />thanks again----------------Bill
i am having this problem to you mention to check the vent line want and were is this i have a 1974 70hp johnson. i have put in new fuel pump,fuel line to carb and new fuel line with 2 primer bulb and new gas tank
the old fuel pump i took of i took apart it looked to me.but inside is a plastic disc with a spring on it it pushes out but it was of to one side and should be in the centre would this keep the pump from pumping enough gas
