Primer Bulb Location?
MX5Jon
I have a 1988 Larson Citation 150 Bowrider w/a 1996 Force 75hp ELPT outboard. Previous owner had it set up with two 6 gal fuel tanks - one under each of the rear jump seats with quick connects to the main fuel line to allow for changing between tanks. All has run well on lots of outings this year.
My problem is that the primer bulb is tucked down under the seats as well. I've since seen a few Bass Trackers boats with the primer bulb located up in the open well for the outboard (far handier to reach). Would there be a problem with me moving the bulb to this location?
Thanks,
-Jon
HAV2FISH
Re: Primer Bulb Location?
You should be able to put it any where you want between the tanks and the motor.
