primer bulb location?
scallop
Where should the primer bulb be located in fuel line in reguard to gas filter?
boscoe99
Re: primer bulb location?
It is presumed that you fuel filter you speak of is mounted in the boat. The primer ball can be located on either side. Makes no difference to the motor. I like it before the filter. Between the tank and the filter. Makes it much easier to refill the filter when a new filter element is installed.
Capt Ken
Be sure to install the primer bulb with the arrow pointing up.
JustJason
Be sure to install the primer bulb with the arrow pointing towards the engine. :p
