PRIMER BULB
5466JOHN
MY PRIMER BALL PUMPS UP GOOD UNTIL I START THE MOTOR, IT GOES COMPLETLY FLAT, BUT RUNS. AFTER RIDING WOT FOR ABOUT 10 MINUTES I LOSE POWER AND RPM. MOTOR WILL IDLE OK, BUT WHEN I WOT IT SOMETIMES ITERMITENTLY RUN GOOD THEN STUTTER. EVINRUDE 1979 100 HORSE.
Brew2
Re: PRIMER BULB
First, welcome to iboats!<br /><br />Second, lose the caps...it looks like you are YELLING!! Lot tougher to read too.<br /><br />Third, if you bulb is going flat while motor is running, I'd first look to your gas tank vent for a clog. <br /><br />If that doesn't work out, report back and I'm sure someone will help.<br /><br />Good luck!!
5466JOHN
Re: PRIMER BULB
Im new to boating so bear with me. The vent I think is ok, if its the same one that spills gas when I fill it.
dragula65000
Re: PRIMER BULB
You may simply just have an old primer bulb. There are different types of rubber used on primer bulbs. I thought I had a bad one, so I bought a brand new one, and it went flat, so I used the heavier duty one, which was the original. Do you have a seperate tank or a permanent tank? Permanent, you have to check all the vent lines, and make sure no vents are clogged. Check to see if all your fuel lines on the carbs are tight as well, and feed lines going to the tank.
Barnacle_Bill
Re: PRIMER BULB
I'm not sure what you were saying, but the fuel tank vent is seperate from the filler hole. You could borrow a portable tank and try running it off it and see what happens.
5466JOHN
Re: PRIMER BULB
Its a new primer ball, with arrow towards the motor, permanent tank, the vent that spills gas when I fill it is not the same hole I put the gas in. Is there more then one vent?I just replaced all gas lines and all connections are tight, also replaced fuel pump, and had carbs cleaned .
Brew2
Re: PRIMER BULB
As a starting point, I'd go along with what IBNFSHN suggests and try a separate portable tank.<br /><br />For testing purposes, you could probably get away with a jerry can and a helper to hold the fuel line in the can (disconnect the fuel line where it connects to the fuel outlet likely in the motor well on the boat)while you test things out.<br /><br />If it fixes the problem, then you've narrowed the problem to your fuel tank. If it doesn't, then you eliminated the tank and can move on to other trouble shooting options.<br /><br />Cheers.
