Should the primer bulb always get hard? On a in floor tank.
F Franklinp Recruit Joined Apr 28, 2003 Messages 3 Apr 30, 2003 #1 Should the primer bulb always get hard? On a in floor tank.
Joe Reeves Supreme Mariner Joined Feb 24, 2002 Messages 13,262 Apr 30, 2003 #2 Re: primer bulb Franklinp.... It should get hard when you pump it to prime the engine fuel system, but it does not stay hard when the engine is running.
F Franklinp Recruit Joined Apr 28, 2003 Messages 3 Apr 30, 2003 #3 Re: primer bulb I can pump it for ever and it won't fill. I tried a new one,same thing. If I remove the bulb I can suck gas through.I don't get it.
Joe Reeves Supreme Mariner Joined Feb 24, 2002 Messages 13,262 Apr 30, 2003 #4 Re: primer bulb Franklinp... The outlet end of the fuel primer bulb must be facing up in order to work properly. Most primer bulbs have a arrow to indicate the direction of the fuel flow.
