green head
- Joined
- Oct 31, 2009
- 37
I have a 1987 Evinrude 20HP Model #E20CRCUR. In the last month I had the boat on the water(pulled it this week) I was having problems with the motor getting fuel. I narrowed it down the primer, I think. The first time it happened I was running at full throttle and the motor slowed and died due to fuel exhaustion. I was checked some obvious things and found the primer was not pushed all the way in. After I pushed it in all the way the motor worked like normal. The next few times it happened I had to push the primer in all the way or leave it out a few millimeters. It seemed that when the primer was in the sweet spot that the fuel flow was uninterrupted to the carb. Does this even make since or just a weird coincidence? If I am onto something is there a way to further troubleshoot or fix this issue.
Thanks
Thanks
