Hi All, I have an 84 Evinrude 50 hp that uses the very popular primer with red lever. I was always under the asssumption that when you needed the extra fuel for cold starts that you just hold the key in, the solenoid moves the plunger to a position that then allows the fuel pump to push the gas through the primer and through the small hose into the carb base. My local boat mechanic said you should push the key in and out a few times and every time you do the plunger pushes out a fresh shot. Anyone know for FACT which is right/ which supplies more fuel? Thanks, Ken
