Hey guys .
I recently bought a boat with a 1987 Johnson VRO 140Hp engine . (Vro is bypassed)
So i have trouble getting it to WOT . It bogs down.
Idle seems okay .
I purchased 4x new Champion Spark plugs QL77JC4
Replaced a cut off fuel line leading to one of the carbs.
Replaced a broken spark plug cable .
So after all this, i thought the engine would of been acting properly..but it's not.
I then, decided to change my carbs gaskets and seals , but when doing so, i saw something strange , cylinders 1 and 3 has 16 and 28 sized jets . & Cylinders 2 and 4 has 20 & 28 sized jets . Is this normal ? Would that cause some issues with accelerating, or bogging ?
Anyways, i cleaned my carbs with carb cleaner, and the jets with pressurized air, purchased 4x carb repair kits. Installed them.
Took it in the water, ran fine for an hour. After the hour, started to bog again.. Thought maybe my fuel pump had something.. so i took it apart, found nothing in it.
But after reinstalling the pump , noticed another broken bleeder line .
After all that, my engine just wont start, keeps flooding itself.. did i break my fuel pump ?
If so , knowing that the engine is 30years old, the vro has been removed and replaced by a standard fuel pump..Which fuel pump am i suppose to purchase... Even my johnson/evinrude/brp retailers here, arent quite sure, which pump to sell me..
A part number would be great to have..or a link, that ships to Canada.
Thanks
Idle seems okay .
Thanks
