A couple months ago I bought a 1997 21' John Storie's Hawk bass boat with a 225 hp Mariner. It has a 25 pitch 4 blade stainless steel vented prop. There are four vent holes, and two of the holes have plugs with what looks like medium or large holes. It also has a jack plate.
This boat will only run about 58 mph, which seems way slower than this boat should run. It also blows out of the hole on takeoff...in other words, it starts to shoot you out of the hole but just before it planes out the rpm's increase drastically but you aren't gaining any speed.
I tried this boat skiing over the weekend and was very disappointed. I had an old 85 hp last year that performed as good as this boat.
When there are only two people in the boat it doesn't jerk the skier out of the water like you think it should. I tried double-skiing (pulling up two skiers at once) and it took 4 tries and pulling the skiers all over the lake before it pulled them up. It just seems like it doesn't have enought power to get them up.
Is this a prop issue? Do I need a lower pitched prop, plug more vents, plug vents with smaller holes?????
Any help you can give is greatly appreciated.
