Problem Selecting neutral
Taz59
1995 3Ltr LX
Goes into forward gear ok,then move to neutral position but still in forward drive.
Goes into reverse gear ok,then move to neutral position but still in reverse gear.
Cheers
Taza
zbnutcase
Re: Problem Selecting neutral
Probably a sticking lower shift cable, or a problem in the control itself.
sea flower
Disconnect your cable(s) from the bracket and carburetor. You should be able to move the shift cable that goes to the outdrive by hand. Move your throttle forward and reverse to test that cable. If they move smooth then reattach them except the carburetor and try it again. If they work smoothly then you have an outdrive issue. If not then you have to adjust them to match the throttle to the drive. It happenned to me. Then I found I was shutting down everytime I shifted. Really, measure the distance they travel and adjust accordingly.
Fishermark
What drive? Sounds like the interrupt switch is not working or someone disconnected it because the engine was dying.
Taz59
Hi
Thanks for replies,interupt switch is working
