Problem solved
cshyde
Found my answer on another web site. They were a great help.
roncoop75
Re: Need advice on prop change
If you've got anybody in your area that reworks props, they should be able to measure pitch for you.
Sometimes the numbers are stamped on the end of the prop, just outside the splined hole. You may have to take off the nut and washer holding the prop on and look underneath, or you may have to take the entire prop off.
cshyde
Re Problem solved
Re Problem solved
On another boating web site.
