I have a merc sportjet 90. Problem is when I try to start motor it pop's off but won't start. After enough choking and grinding of the starter and feathering of the throtle it will start. Also when started if I go WOT it will bogg down sometimes will die even, especially right after startup. It does this cold or hot. Seem like I have the need to choke it alot but it will flood if done too much (of course). I have put a new Stator,CDI, and fuel pump on it and test the compression, all seem to be good. I'm thinking about a carb overhaul now. Just wondering if there might be something easier of something different all together to look for.
Thanks in advance.
Thanks in advance.
