Problem with 1967 Johnson 4 cylinder
Patty Pooh
I am having problems starting my motor. When i crank it over it just barely pops then cuts out. I think there is a problem in the fuel system. When I put a little fuel directly in the carbs and a squirt in each cylinder it will run for a few seconds then cut out. The few seconds it runs it sounds real good. Any Suggestions? Thank You!!!
ob
Re: Problem with 1967 Johnson 4 cylinder
Sounds like the carburetors are fouled ,possibly with gummy deposits.Has the motor sat idle(out of use for a time?)<br />You can check to see if the fuel pump is moving fuel at cranking speeds by disconnecting the dischrge hose and routing into a container while cranking.
Patty Pooh
How do I Clean Carbarators? The kind i have has a sediment bowl
