Hi,
I have a small boat in Mexico, with a 25hp Johnson 1984. I just come back from a 3-4 weeks trip with it, fishing almost everyday strating from the shore.
The motor was running fine but things seem to get worse and worse: the plugs was getting dirty as well as the pistons and everyting inside the engine.
Use: The motor was used 90% of the time for trolling at 7-9 kmph.
Symptoms: with new plugs the motor start fine, but after few hours the plug get dirty, to the point that the motor have some misfiring (the accelaration is not fluid at all, it stops and restart accelerating) and its getting worse and worse. It only restart replacing the sparkplugs. Sometimes going faster for few minutes have made things better. The problem is that, we have been doing that during 3 weeks and I think the motor is dirty inside (when we srew off the dirty sparkplugs, the piston inside look dirty).
The motor have no termostat (they took it off), but the water is 83 degres Fahrenheit. The water out of the cooling pump looks 10-15 F degres hotter.
It is written on the motor 100:1 concerning the oil mix. We tried both 100:1 an 50:1. It just looks that the sparkplugs where getting dirty faster.
The only sparkplug available in Mexico were the champion L92YC and NGK B8HS10 and B7HS10
The champion were better, the motor was dirty after 20 hours running one time, and we retried them another time after trying the NGK at the end, it was dirty in few hours.
The NGK were much worse, everytime dirty quickly.
My opinion
The plugs aren't the good ones. I should bring the good plugs to Mexico (champion JC4) next time and cleen the motor with Seafoam.
My question
What do you think ? Can that be some other problems ? (thermostat?)
Thanks everyone
My opinion
My question
Thanks everyone
