Problem with both up/down trim - no click
focker1636
Alpha 1Gen II trim on 2001 Mercruiser 5.7L
Trim is in up position now, as it has been all winter. Neither up or down trim works, with no click from either solenoid. Solenoids are dark at tip but shiny down the posts.
Here's what I have done and tested so far:
1. Removed each terminal wire on the solenoids one by one, cleaned the posts and the connected wire with sandpaper, then reconnected.
2. Tested 110 amp fuse with meter. Voltage both to the fuse and when trim switch is engage on the other side of fuse OK. Removed 110 amp fuse and tested with Ohm meter. Reading is 0 to 1, which I understand means the fuse is likely OK.
3. Jumped both posts on up and down solenoids, but did not encounter spark as expected. Would have expected to be able to arc the posts if the root cause of the problem is bad solenoids.
4. Ran 10 gauge jumper wire from 12+ to green wire with no activity.
5. Removed wiring harness assembly and made sure it did not appear corroded and is connected securely.
6. 20 amp fuse appears OK.
The fact that I got no sparks or action of any kind when jumping solenoid posts is an indicator no power is getting to solenoid, right?
What else am I missing or should try?
Thanks!
Re: Problem with both up/down trim - no click
Ayuh,... Sounds like ya didn't hook up the Ground wires...
focker1636
Oh yea, battery appears to be OK. I can start the engine with muffs on the first turn of the key.
focker1636
They are connected. As I said, I removed each set or single wire from each post, cleaned then replaced, and made sure the nut was secure.
focker1636
Don, this is the exact document to which I've been referring when troubleshooting. Possible the ground wire is bad?
Don S
Anything is possible, we can't see it from here.
Try this. IF you have a test light, hook the clip to the POSITIVE battery terminal, then touch the tip of the light to the ground bolt on the trim pump bracket. Does the light light up?
Ayuh,... Run a jumper from battery (-) to the pump housing frame, 'n retry yer tests...
focker1636
Yep, appears to be a bad ground line. Ran my test jumper from neg on battery to ground post and trim now works. Well, at least I know where to focus now.
Thanks for the help, guys!
focker1636
As a side note, I believe that boat designers are in league with the chiropractic community.
