PitchFork
- Joined
- May 28, 2009
- 313
Alpha 1 Gen 1 1979 GM 350 4bbl
I was running across the water at 35MPH and the boat died for a second and continued on for 5 seconds and then dead in the water. The boat was still running but would not go into gear. No noise when trying to put into gear. Also the temp rose to 190?. No water in lines. It's like the lower drive shaft is not turning in which turning the impellar.
I never smelled burning rubber which I think it tells me that the coupler is fine.
Any ideas? What tool do I need to pull the top off to get to the upper gears? How hard to change upper gears?
PF
PF
