Problem with EVC-E (Exhaust temperature)
We have vessels with two new D6-370 engines with an EVC-E configuration. Immediately after starting both engines, the following message is displayed: high temperature exhaust gases, please reduce the revs. We find this strange, because that is impossible with a cold engine. We can push the report away in the EVC, but it will remain.
My first guess is the sensor, or if you have a European model may be the wire on the sensor is not making a good connection
Do you have good water flow thru the exhaust?
