I recently replaced the fuel pump, filter, water seperator and tightened all fuel line connections. Cleaned the carbs and pumped the bulb for a long time figuring that the seperator need to fill and some air made its way into the lines. After a while of pumping the fuel bulb, I could feel and hear some fuel going through the bulb but not a lot. The bulb did not become firm at anytime. I could see gas going into the fuel filter then I stopped. I started the engine without an issue. I brought it to the water the next day and I couldn't feel or hear any gas going throught the bulb. The engine started and ran unaffected.
What do you guys think?
thanks
P.S. If you think it is the bulb or a fuel line, can you recommend a brand to buy?
thanks
