seven_magnum
- Joined
- Oct 4, 2011
- 127
My restore thread is here
http://forums.iboats.com/forum/boat...t-islander-221-rebuild/page13?_=1440814246091
I'm up against a wall- I am trying to get the gimbal assembly in the boat but its not happening- the steering arm at the top interferes with the top of the key hole? I can't get it in for the life of me. I am trying to use the "new" gimbal assembly and wondering if there is a difference? The boat had a '76 Mercruiser 165 with MC-1, I am installing another Mercruiser 165 with MC-1, at least I thought? I took the gasket, and it matches the gimbal ok, but needed trimmed- the local boat shop I bought it from just said make it fit at the bottom, that's why she's cut down there. Anyhow, the bottom holes match up fine, but then the top two studs are in the wrong place? I would like to use this housing because it's in much better shape than the old one, but to do that I need to drill new holes in the transom at a minimum. Any help would be great!
