Problem with Lowrance with two running.
Darol Wester
I have a Lowrance x-86 running up front and a second one in the back which is a Lowrance 96. When they're both on, the 96 isn't accurate. It kind of jumps all over or sometimes it's close to the 86 which is working right. I had a Lowrance x-60 back there before and they both worked fine. I ran the 96 on another boat and it works fine by itself.
Think maybe the transducers need to be farther apart or are there other issues?
Darol Wester
Re: Problem with Lowrance with two running.
Well, when I had the x60 on there, the transducer on the left was swapped with the speed wheel and it worked fine. When my problems began with the 96, I did swap the two to where they are now with no improvement. Well sheet. Think maybe I'll run it to the other side back there.
Thanks!
